V4/M4's morph targets not loading into Poser10?
Just had to rebuild my computer after the harddrive crashed, and am having NO LUCK getting V4 and M4's morph tagets to load correctly into Poser10. I've set P10 to use normal libraries, as I'm the only one using it in my world. The newest downloads I've gotten from you only have content/runtime folders instead of the old content uploader programs you used to have, and when I load the folders into my Runtime folders, the morph targets don't work, and the only onboard morphs available are the male morphs. I tried loading S4, and all of her morphs came in at the bottom of the figure, and do not work. I presume SheFreak4 is going to do the same thing.
As far as I can tell, I've done what your readme said to do - load Vicki into the root Runtime folder, instead of the Downloads/Runtime folder - and I'm pulling my hair out trying to get it to work.
I'm SURE this has been covered repeatedly, so I apologize. Everything I thought I was supposed to do isn't working.
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Don't install to the application folder - use the default Poser content library, or add another one, instead. Did you use Install Manager to install? If not, go to \Runtime\Libraries\!DAZ in an OS file window and run the DzCreateExPFiles-v4 and DzCreateExPFiles-m4 commands for your operating system. Then you need to go to the Pose library and in DAZ's Victoria 4>Morph Injections use the INJ pose for the base morphs, and any expansions you have, or the equivalent for Michael.
