get D-Former from Morph
I've spawned my morphs from D-Formers created in DAZ... But I deleted the D-Formers while spawning, is there a way to get the D-Forms again? Or do I need to create everything from scratch?
  • Richard HaseltineRichard Haseltine Posts: 111,923
    I'm afraid the dForm doesn't leave any history, not even that the morph was created from a dForm (instead of another tool in DS, or a bridge to another application, or a simple OBJ import/export) so theer isn't any way to reverse the process if you don't have a saved scene or dForm preset.
  • arthur.kenichiarthur.kenichi Posts: 2
    edited June 2025
    thank you! Is there any workaround I could try, like selecting the vertices of the Morph and creating a D-Former with those?
    EDIT
    also, I did something wrong that now D-Formers don't show Unused Maps to be added when I select Weight instead of Sphere. DAZ crashed. What could I be doing wrong? Should I reinstall?
    EDIT_2
    I restarted the program multiple times and it fixed the problem in the EDIT. Also, I selected all the vertices the Morph affects and filled the Weight Map and started painting and smoothing them so I create a new morph and I won't delete the D-Formers this time. But I have another problem: I forgot how to add the same D-Form to multiple objects, like moving the eyelashes when moving the eyes.
    Post edited by arthur.kenichi on
    Select the node(s) you wish to include, then in the dForm pane click the Add Influence to Selected button and pick the dForm(s)you want applied.
    thank you for the help!! you are the best! :D
