Point light issue
Hi team, I've just started using a point lights to illuminate an interior. So, I placed my first point light just below the scenes ceiling light, set to rectangle, increased the rectangle area and luminosity. Now I thought that point lights emitted light through 360 deg. but when I rendered, only half the room was light up, it was like a slice had gone right through the middle of the room. Playing around a bit, I found I had to actually turn the point light through 90 deg. to get it to illuminate the whole room. Can someone explain why this is please?
Many thanks
  • DrunkMonkeyProductionsDrunkMonkeyProductions Posts: 1,337
    edited June 2025
    It was the change from Point to Rectangle in the LIght Geometry.
    This changes the light from being a little ball with 360 degree illumination to a flat plane with a single direction of illumination.
    The plane is oriented -90 degrees on the x rotation, in relation the the 'floor'.
    Post edited by DrunkMonkeyProductions on
  • Many thanks DMP, I did not know that, but I do now! Cheers
