AM: Great White missing [Rodent eye] file?
I am having an issue with the Shark Attack Scene with the item:
https://www.daz3d.com/sharks-by-am-great-white
When I try and load it I get a missing file error as follows:
/Runtime/Textures/AM/Rodents by AM/SquirrelEyes-D-AM.jpg
I checked the file list for this product and there is no such texture?
    edited June 2025
    Yes, the product is faulty. The Shark Attack Scene file has the female shark's sclera surface Translucency Color set to the squirrel eyes texture file. The Translucency Weight is 0.00, though, so I think you can safely ignore the error message. The squirrel eye texture is from a different product by AM. If you happened to own it, you wouldn't see the error message.
    You could submit a help request about the error, but I'd bet the chance of ever getting a fix from Daz is about zero.
    You could just change the Translucency Weight to something above 0, so you can see the Translucency Color, and then delete the image in the Translucency color. Set the Translucency weight back to 0 and then overwrite the product scene file with your corrected scene file. Then the next time you loaded the scene, the error would not occur.
    Post edited by barbult on
