Easy Tattoo Maker
 I've been trying to add tattoos to skins but they always come out terrible whenever on a tricky place, for example, a spine tattoo will need to be divaded and one half goes to the left of the skin and the other to the right. You then have to make the curvature correctly and align them. It's pretty tough. I feel like a product that helps with this issue would be very welcomed
  • felisfelis Posts: 6,445
    If a product should help you it should project the texture onto the body, and then bake it to textures. Whether that is feasibly I don't know.
    You can use a decal node to project it, but it is dependant on pose.
    Else you can do 3d painting in an external application.
  • Richard HaseltineRichard Haseltine Posts: 111,011
    One way would be to remap the model (in Hexagon or Blender say) to get a nice UV in the area of interest, and let the rest go to hellp. Apply your tattoo image using that and then bake it to a map using the standard UV set, ready to be applied on top of the regular textures in an image editor or using Layered Image Editor in DS.
