?microphone yoo use with Mimic Pro?
MistaraMistara Posts: 38,675
make/model?
Thanks.
i put windscreen puff on my pc mic.
But considering the work of recording dialong, thinkin i should start with something better.
as near as i can tell,  i need a condenser mic?  24-bit or higher?
the hertzes pertain to octave range?
i see the sony acid supports 24bit, not sure about the soundforge.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,659
    I use a Shure omni directional one
    thanks,  do yoo record straight into your pc?
    smileysmiley​smiley​smiley​smiley​smiley​smiley​smiley​smiley​smiley​smiley​
    Yes the line in plug using Morph Vox and Audacity (you can pick Screaming Bee as the mic input in Audacity)
    this is a shure, says up to 24bit.    was also looking at a blue yetti.  forgot to bookmark it >.<
    mine not fancy like that
    A dirctional mic is better than an omni.  It makes it easier to eliminate room noise and isolate just the voice.   A 'cardiod' or 'super-cardiod' pattern is best for vocal recording.  Condenser mics are very good for vocals, but may require extra hardware (a pre-amp, if it doesn't have one built in...that's something to look at in the specs).  Dynamic mics are fine, too...they don't need a pre-amp.
    A good headset, with a high quality mic (some of the gaming headsets...the upper end ones) can be better for voice work than a stand alone mic.  The mic is close to the source, designed for vocal frequencies and moves with you if you move your head.  Being close to the source means less room/background noise and lower input levels, which means lower, overall noise.  Being specifically desgined /tuned for voice means better clarity, less distortion and lower noise (hiss, etc).  Moving with you...should be obvious.  With a directional stand mic, there is very little room for movement...and sitting at a computer while recording isn't really an optimal position to do it...there is a reason vocal artists/singers stand when performing/singing.
