Updating Geometry lasting forever with Kintsugi inspired skin builder for G9
jmucchiellojmucchiello Posts: 2,162
UPDATE: I removed almost everything from the scene. It turns out the Kintsugi geoshell I'm using is the reason. Remove it and everything works fine. Put it in the scene and it hangs on render with no info. There are no errors at all in the log. It just loads a bunch of textures, 7.2GB according to task manager, and then hangs at the updating Geometry stage. https://www.daz3d.com/kintsugi-inspired-skin-builder-for-genesis-9
The weird thing now is I've done renders with this asset before. I have no idea what changed.
----- original post below ------
I will never understand this. Daz spent over an hour "Updating Geometry". 3 or 4 CPU cores ran at 100% utilization during that time. Nothing updated in the log during all that time.
Of course, I'd love to have an explanation of what the VDB warnings mean as well:
2025-05-31 15:39:08.246 [INFO] :: Rendering image...2025-05-31 15:39:15.209 Iray [INFO] - IDXVDB:MAIN ::   1.0   IDXVDB main info : VDB data cache: opening D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/Plume A.vdb...2025-05-31 15:39:15.211 Iray [INFO] - IDXVDB:MAIN ::   1.0   IDXVDB main info : VDB data cache: done loading D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/Plume A.vdb.2025-05-31 15:39:15.214 Iray [INFO] - INDEX:MAIN ::   1.0   INDEX  main info : Sparse volume subset host data: detected min/max range: min = [0.000000], max = [0.376221].2025-05-31 15:39:15.214 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IDXVDB:MAIN ::   1.0   IDXVDB main error: OpenVDB_importer_sparse_volume_dataset_property_provider: failed to retrieve bounding box from OpenVDB file 'D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/Plume A.vdb'.2025-05-31 15:39:15.214 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - APPLYR:MAIN ::   1.0   APPLYR main error: failed to call load_dataset_properties: nv::index::plugin::openvdb_integration.OpenVDB_importer_sparse_volume2025-05-31 15:39:15.215 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - INDEX:MAIN ::   1.0   INDEX  main error: Failed to create OpenVDB importer.2025-05-31 15:39:15.215 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - TEXTUR:IO ::   1.0   TEXTUR io   error: failed to load flames from volume data D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB\Plume A.vdb2025-05-31 15:39:15.216 Iray [INFO] - IDXVDB:MAIN ::   1.0   IDXVDB main info : VDB data cache: opening D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/FlamePortalC.vdb...2025-05-31 15:39:15.223 Iray [INFO] - IDXVDB:MAIN ::   1.0   IDXVDB main info : VDB data cache: done loading D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/FlamePortalC.vdb.2025-05-31 15:39:15.233 Iray [INFO] - INDEX:MAIN ::   1.0   INDEX  main info : Sparse volume subset host data: detected min/max range: min = [0.000000], max = [0.139160].2025-05-31 15:39:15.233 Iray [INFO] - IDXVDB:MAIN ::   1.0   IDXVDB main info : VDB data cache: opening D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/FlamePortalC.vdb...2025-05-31 15:39:15.240 Iray [INFO] - IDXVDB:MAIN ::   1.0   IDXVDB main info : VDB data cache: done loading D:\Daz3D\Runtime\Textures\Kindredarts\KARCFXTX\VDB/FlamePortalC.vdb.2025-05-31 15:39:15.247 Iray [INFO] - INDEX:MAIN ::   1.0   INDEX  main info : Sparse volume subset host data: detected min/max range: min = [0.000000], max = [0.305420].2025-05-31 15:39:20.537 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.2025-05-31 15:39:22.443 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 1.907 s.2025-05-31 15:39:22.483 Iray (Scene Traversal) : Initializing update2025-05-31 15:39:22.483 Iray (Scene Traversal) : Retrieving journal and checking for changes2025-05-31 15:39:22.483 Iray [INFO] - POST:RENDER ::   1.0   POST   rend info : Postprocessing denoiser is enabled2025-05-31 15:39:22.483 Iray (Scene Update) : Updating LPE labels2025-05-31 15:39:22.483 Iray (Scene Update) : Updating geometry contexts2025-05-31 15:39:22.483 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
At 16:44, I hit cancel. The CPU utilization dropped to zero. It's been 10 minutes since I hit cancel. Did it start responding? Nope.
Where do I even begin to look for this? I rendered this file earlier this morning with a different camera. No issues. 8 minutes tops.
352 x 383 - 16K
Post edited by jmucchiello on
  • jmucchiellojmucchiello Posts: 2,162
    I completely removed the VDB spell effect from the scene file and it still hangs. There are a handful of CPU busy, but not pegged at 100%. The GPU is 0%.
    2025-05-31 17:29:59.007 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2025-05-31 17:30:02.813 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 3.806 s.
    2025-05-31 17:30:02.869 Iray (Scene Traversal) : Initializing update
    2025-05-31 17:30:02.869 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2025-05-31 17:30:02.869 Iray [INFO] - POST:RENDER ::   1.0   POST   rend info : Postprocessing denoiser is enabled
    2025-05-31 17:30:02.869 Iray (Scene Update) : Updating LPE labels
    2025-05-31 17:30:02.869 Iray (Scene Update) : Updating geometry contexts
    2025-05-31 17:30:02.869 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
    2025-05-31 17:30:02.869 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
  • Richard HaseltineRichard Haseltine Posts: 111,475
    Does it clear up if you disable canvasses?
    I'm not using canvases at all. I've reduced the scene to a single figure. A room. And the Kintsugi shell. It hangs. But I've done other renders with the same kintsugi shell asset.
    MikeD's List of Products Used is fairly accurate:
    Products used: =========
    - Addy Gemma and Expressions for Genesis 9 (Main figure, face only)
    - DD PBR Marble Shaders for Iray (geoshell, currently hidden)
    - DirtFX for Genesis 9 (geoshell, current hidden)
    - Genesis 9 Body Shapes (Main figure)
    - Hospital Props
    - Iray Skies 4 - 10 Skies (HDRIs) for use with Iray (The Dome)
    - Kintsugi Inspired Skin Builder for Genesis 9 (geoshell)
    - LI Magic Mirror
    - PfX Valeria HD for Genesis 9 (Main figure, body and face)
    - Side Parted Long Bob Hair for Genesis 9 (Main figure)
    - Side Parted Long Bob Hair Texture Expansion (Main figure)
    - Urban Art Studio (The room)
    There were a few stray items but they've been deleted.
    My next step is start with a blank scene and create everything from scratch to see what happens. This will be tedious.
    485 x 194 - 8K
    It's definitely something wrong with the kintsugi asset.
    I just create a new scene. Empty.
    Create a figure using People\Genesis 9\Character\Pfx Valeria.duf
    Move some sliders
    (Save :) )
    Render. no problems, tool only 1 minute. (No cameras or lights are in the scene file. I assume the Ruins500b hdri is lighting the scene.)
    Add Kintsugi Geoshell.
    Render. It hangs.
    2025-05-31 19:16:34.590 [INFO] :: Rendering image...
    2025-05-31 19:16:39.438 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Nails\Nails 1005_BaseColor.png", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.439 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Nails\Nails 1005_Roughness.png", no selector, pixel type "Sint8", 2048x2048x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.440 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Nails\Nails 1005_Normal.png", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.444 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1003_BaseColor.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.444 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\SSS\Valeria 1003_SSS.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.444 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1003_spec.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.445 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1003_Normal.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.498 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\runtime\textures\daz\characters\genesis9\base\skin_details\genesis9_legs_nm_1003.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.503 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1001_BaseColor.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.503 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\SSS\Valeria 1001_SSS.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.504 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d16_Makeup Color_d82bc223-f9b5-b86f-9f8e-41e5c07d9ed1 4.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.505 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d15_Makeup Weight_fdfbe699-e1a3-fdd3-c9a1-411f08f07e83 4.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.506 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1001_Normal.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.579 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\runtime\textures\daz\characters\genesis9\base\skin_details\genesis9_head_nm_1001.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.584 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1004_BaseColor.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.584 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\SSS\Valeria 1004_SSS.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.586 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1004_spec.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.587 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1004_Normal.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.609 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\runtime\textures\daz\characters\genesis9\base\skin_details\genesis9_arms_nm_1004.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.612 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1001_spec.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.615 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1002_BaseColor.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.616 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\SSS\Valeria 1002_SSS.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.616 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1002_spec.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.616 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Valeria 1002_Normal.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.650 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\runtime\textures\daz\characters\genesis9\base\skin_details\genesis9_bodyf_nm_1002.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.731 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Eyelashes\Valeria_Eyelashes_albedo.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.732 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\PrefoX\PfX Valeria\Eyelashes\Valeria_Eyelashes_normal.png", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.734 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\DAZ\Characters\Genesis9\Base\G9TearOpacity.jpg", no selector, pixel type "Rgb", 1024x1024x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.737 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\DAZ\Characters\Genesis9\Base\G9TearNormal.tif", no selector, pixel type "Rgb", 1024x1024x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.740 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d19_Valeria_eyes_slw-3_6a8f4dcf-aef9-4c80-a3ed-2e6a5092a63f.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.740 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d17_Eye Color 2-3_cea7b68e-55ab-4337-a385-b70e0bd525c5.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.741 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d20_Eye Normal 2-3_ce3c3fc1-7188-2eb4-a793-5e3e8339e2d9.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.742 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d21_Eye Color 2-3_e496c88d-3e1b-b59e-9e2a-f4eb08f4050a.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.742 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d22_Eye Translucency 2-3_e496c88d-3e1b-b59e-9e2a-f4eb08f4050a.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.743 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d23_Valeria_eyes_slw-3_g9_eyes_slw.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.744 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d24_Eye Normal 2-3_9f55213e-fa9a-8bd0-98bc-56038f9d9f7e.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.748 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d27_Valeria_eyes_slw-3_1cc7139b-f008-433a-87b7-46551092a3c9.png", no selector, pixel type "Rgba", 2048x2048x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.749 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\d25_Eye Color 2-3_921f695a-4a4a-43c8-8f1f-bd4e8bc3c21f.png", no selector, pixel type "Rgba", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.756 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\DAZ\Characters\Genesis9\Base\Genesis9_Mouth_D_1001.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.759 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\DAZ\Characters\Genesis9\Base\Genesis9_Mouth_R_1001.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:39.767 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\DAZ\Characters\Genesis9\Base\Genesis9_Mouth_NM_1001.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.540 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\Transparencies\MissingSections\Missg9_Mask4096.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.541 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Fingernails_Opacity.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.544 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\Plain\g9_Arms_BaseColor.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.545 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Fingernails_Normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.545 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Fingernails_Height.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.546 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Toenails_Opacity.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.547 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\Plain\g9_Toenails_BaseColor.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.548 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Toenails_Normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.549 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Toenails_Height.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.550 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Legs_Opacity.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.553 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\Plain\g9_Legs_BaseColor.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.558 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Legs_Normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.559 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Legs_Height.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.561 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Arms_Opacity.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.564 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Arms_Normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.564 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Arms_Height.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.566 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Head_Opacity.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.568 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\Plain\g9_Head_BaseColor.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.573 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Head_Normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.574 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Head_Height.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.576 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Body_Opacity.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.579 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\Plain\g9_Body_BaseColor.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.583 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Body_Normal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:44.584 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D\Runtime\Textures\ForbiddenWhispers\KintsugiG9\Cracks\CracksBase\g9_Body_Height.jpg", no selector, pixel type "Sint8", 4096x4096x1 pixels, 1 miplevel.
    2025-05-31 19:16:45.105 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\Daz3D-Install\Applications\64-bit\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2025-05-31 19:16:45.106 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2025-05-31 19:16:46.685 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 1.579 s.
    2025-05-31 19:16:46.744 Iray (Scene Traversal) : Initializing update
    2025-05-31 19:16:46.744 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2025-05-31 19:16:46.744 Iray [INFO] - POST:RENDER ::   1.0   POST   rend info : Postprocessing denoiser is enabled
    2025-05-31 19:16:46.744 Iray (Scene Update) : Updating LPE labels
    I guess I should uninstall the kintsugi asset and reinstall it? Not sure what's left.
    In DIM, uninstall, delete. Download, install. Open file with figure apply geoshell.
    What kills me is the viewport IRAY rendering works just fine, see attached.
    Render. Same issue.
    I'm not sure what this is but it's the only thing interesting in the logs. This log entry has never happened before until just now.
    2025-05-31 19:29:39.189 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - TRIT:GEOMETRY ::   1.0   TRIT   geo  warn : Object DS_shape_380a_683: the parametric approximation level is set to 2. The original value of 6 would produce too much geometry in a single mesh.
    I don't know what to do now.
    792 x 960 - 303K
    The saga continues. New scene. Create a G9 base figure. Apply Kintsugi geoshell. Renders just fine.
    Apply Pfx Valeria body/head. Renders just fine.
    Add all the other shape modifications. Renders just fine.
    Somehow, starting with Pfx Valeria and making shape morphs is different from starting with G9 Base adding Pfx Valeria shape morphs and then other shape morphs.
    Losing my hair.
