Having Problems With Elite Ponytail
Hello All,
I have been trying to get the Elite Ponytail for Genesis 2 Females to work on Genesis 3 females.  I have no problem using the fit to option.  But once the hair is attached to the figure, I can no longer use any of its poses or material presets.  Everytime I try to, nothing happens.  Is there something I need to do to get these to work?  Please, any help will be greatly appreciated and thank you for your time!
  • LyonessLyoness Posts: 1,641
    With that hair, I have trouble using the ponytail poses after CONFORMING it to G3F.  This is because the joints get overwritten in the conforming process.  However. if you have the hair selected in the scene, you should be able to change the hair colors using the library without any problem.
    Instead, what I often do is PARENT the hair to the head.  That keeps the ponytail bones intact so that I can still move it around. Then when I select it, I can easily use the poses from the library.
  • Thank you so much Lyoness!  Such a simple answer but I never would have figured it out without your help.  Thanks again!
    My thanks as well. This should solve a problem with some v4 clothing morphs on G2F.
