XI Presidential Office Renders
I am not sure if anyone else has seen crazy slow renders from https://www.daz3d.com/xi-presidential-office, which is just likely due to it's volume and quality of 'stuff'.  I ran a script to hide from rendering those things that are not in the camer bring rendered, but even withi that it takes like hours to make a single screen render, even after toning down render settings.  I only have the issue with this one.
Does anyone have any advice?
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Did you restart DS after hiding the items? If it had dropped to CPU due to runing out of memory it may well need a restart to free the memory (if I am reading the logs right this may be chnaging in DS 2025). The maps are large and numerous, you might want to use reduced size versions where practical (depends on render size and how big the model in question is in the render) - you can do that manually (workl on a copy) or using soemthing like the Scene Optimizer product https://www.daz3d.com/scene-optimizer .
