Bug? Missing Feature? Hovering over parameter steals focus from entry field?
See the image. When trying to use search parameters (or poses or shaping...) when I put the mouse in the entry field and click, the entry field cursor appears and I can type into box.
But if the mouse drifts downward, when it enters the first parameter, focus is stolen from entry field. And subsequent keystrokes are interpreted by Daz as commands.
Is there a setting to turn this off? I'm running 4.23 if that matters.
I do NOT have focus follows mouse turned on in Windows.
41K
  • Richard HaseltineRichard Haseltine Posts: 111,972
    This has long been the case, I was told it was a Qt limitation - sadly it doesn't (yet) seem to have changed with Qt 6 in DS 2025 Alpha, I don't know if that means it is still a Qt limitation or if it is something that can't be fixed until more work is  done on the UI elements.
  • jmucchiellojmucchiello Posts: 2,594
    Thanks. Just have to remember to kick the mouse up so it doesn't slide down, I guess.
