Putting Poser Content into Smart Content tab?
First of all this is my first post, so hello everyone!
Ok, so I was wondering if it is possible to put content from the poser formats section in content library in to the smart content tab?
Also, sorry if this is in the wrong section
  • fixmypcmikefixmypcmike Posts: 19,729
    Let's say the item is clothing for Victoria 4.  Load Victoria 4 in the viewport and make sure she's selected.
    Open the "Content Library" pane on one side, open to the folder containing the clothing.  Open the "Smart Content" pane on the other side with the category you want to put the clothing in (you can use the Default > Wardrobe category, or you can create your own category).
    Drag the clothing from the Content Library to the Smart Content pane.  It will now be Smart content that is compatible with V4.
  • RenomistaRenomista Posts: 921
    Here a Tutorial on how to creat Missing Metadata, Even thought the example is a DS Format Product it should work the same for Poser Format Stuff.
    http://www.3d-almanac.com/index.php/2016/02/16/tutorial-metadata-101-create-smart-content-metadata-for-3rd-party-content-in-daz-studio/
  • stefan.humsstefan.hums Posts: 141
    Thanks, good to know.
    Is it also possible to export the so created Smart Content data, for the case that the content database would have to be purged and all re-imported? Would things make much easier, with all the chaos in 3rd party content.
    From the options menu (rectangle with horizontal lines in the upper corner of the Content Library or Smart Content pane) > Content DB Maintenance > Export User Data
    Thanks!
