Sci-fi Pilot Outfit with Starship for Genesis 8 Female – Missing File
I bought Sci-fi Pilot Outfit with Starship for Genesis 8 Female (https://www.daz3d.com/sci-fi-pilot-outfit-with-starship-for-genesis-8-female) a few months ago.  There is a material icon for Gun Lazers material file for the Gun but when I attempt to use it, I get a Missing Files pop up window stating that the following file could not be found:
   /data/acharyapolina/Sci-Fi Pilot Outfit With Starship/Sci-Fi Pilot Outfit With Starship Gun Lazers /UV Sets/AcharyaPolina/Base/default.dsf .
There is no /data/acharyapolina/Sci-Fi Pilot Outfit With Starship/Sci-Fi Pilot Outfit With Starship Gun Lazers directory but there are two directories named
  /data/acharyapolina/Sci-Fi Pilot Outfit With Starship/Sci-Fi Pilot Outfit With Starship Gun Lazers 1 and /data/acharyapolina/Sci-Fi Pilot Outfit With Starship/Sci-Fi Pilot Outfit With Starship Gun Lazers 2
and each has a default.dsf file three levels down.
Does anyone have this product and have the same problem?  If not, I need to submit a ticket to get a corrected folder/file.
Thanks.
559 x 435 - 52K
712 x 113 - 20K
916 x 515 - 394K
1466 x 371 - 91K
  • Richard HaseltineRichard Haseltine Posts: 111,374
    Is it actually causing an issue, other than the missing file alert? Usually, if there is only the one UV set, that error will not stop it from using the default set by default. Not saying it shouldn't be reproted and fixed, if it is affecting all users, but it may be an annoyance rather than a show-stopper
  • jjoynerjjoyner Posts: 844
    edited May 2025
    “… but it may be an annoyance rather than a show-stopper.”  It’s more of an annoyance than a show-stopper..  Props load with default settings so the Lazer Gun loads with the laser ray already applied.   The two guns that come with the holsters come without laser rays; if I want to add a laser ray to one of the guns, the material file needs to be used.
    559 x 457 - 69K
    Post edited by jjoyner on
