Graphic Art Cameras....
Ruphuss
.....by Age of Armour are still in the shop-why?
they do not work with 4.9 anf i think they do not work with studio since 4.7
there is a script (not from daz) out. i know.
but it does not work if installed with connect
They are still in the shop for the same reason that Victoria 3 is still in the shop, it sells.
It also clearly states it is 4.6 compatible, not 4.6 plus compatible.
And yeah they apparently broke with the 4.7 update, so as long as you are using 4.6 you can use it.
People don't always upgrade their software to the latest version.
Heck i still run old versions of programs all the time, such as C4d(r14) because a plugin i like(interposer) doesn't work past that.
While my workstation is running daz 4.8, my test box is running 4.9 and i think my file server is running 4.6.
you can only install through connect with 4.9
then its not working
some warnings needed here
YOU DON'T HAVE TO USE CONNECT ONLY WITH 4.9!!!! It can see all properly installed and mapped content just like previous version.
when i want to download with connect which is offered in the store it does not work
