Dark Attic
I picked up the Dark Attic. It looks pretty awesome but you can't seem to take out individual walls. It makes it pretty tough to set up scenes when the camera has to be so close in.
Am I missing something? Any thoughts?
  • Richard HaseltineRichard Haseltine Posts: 111,745
    If you are rendering in DS using Iray then go to Create>New Iray Section Plane and postion the plane to cut off the blocking part of the attic that you don't want to see - by default this will not only allow you to see through the walls but will also let light in, which you probably don't want, so go to the Parameters pane and make sure it iss et to clip lights as well. In Poser or DS using 3Delight you will need to use the Grouping Tool/ Geometry Editor tool to select the wall polygons and then create a new surface from them and set it to fully transparent/0% opacity (or simply hide the polygons in DS)
  • DarkRepastDarkRepast Posts: 226
    Thank you very very much! This is fantastic info. I really appreciate it.
