4.23 Filament Crashes on 0% scale (ticket submitted)
mmdestiny
Just wanted you all to be aware of a bug I've come across in case you have scenes that suddenly start crashing.
Strangely, this scene did not crash until I loaded it for the first time in 4.23 instead of 4.22.
Here's the description I sent in my ticket.
I have discovered a bug where if an object's scale is set to 0% and Daz Studio is set to Filament, the program will crash. I have recreated this bug 100% of the time with either of the following 2 sequences of events.
If already in Filament:
-create a cube
-set the cube to 0% scale
-toggle the cube visibility off, then on. Crash occurs when it is switched on
If in any other render mode:
-create a cube
-Switch to Filament. The crash occurs immediately
The program will also crash if a scene is loaded while in Filament mode and the scene contains an object with scale at 0%.
