Plant Pots - Vol 1 In Store Now!
I make a lot of images with plants, and have always struggled to find containers to put them in, this set of plant pots in various materials and shapes is a great start and simply gives you options of traditional pots to put your plants in! 3 soil materials and the option of teracota , black or brown plastic means there are lots of combinations for you to choose from.
FIND THEM HERE
  • jmucchiellojmucchiello Posts: 2,395
    Is there a way to lower the height of the soil? Wet soil textures? If not, well, there's always volume 2. :)
  • MartinjfrostMartinjfrost Posts: 434
    Lower nig the soil height would be hard to incude as an option as it is basically a disk and thus on a tapered pot it would start to poke out of the sides. However you might be able to do it by going to the surfaces tab and making the soil invisible in there. duplicating the pot and then scaling the duplicate to be slightly smaller in diamater and height than the origional and turning its soil back on.,.. might not be purfect but would be something. Alternativly you could just add a disk from the primitives at the height and scale you need having made the pots soil invisible. its a bit of a fiddle but not too difficult. You could then copy the soil shader on to the disk you have inserted ( making the shader visiable again)
    I will have a think about it if i do a volume 2
     I suspected you hadn't considered it. No big deal. All things can be done "another way". It's just easier when the asset is planned that way. If you "think about it" for vol 2, that's more than I can hope for. Thanks for your great work.
  • memcneil70memcneil70 Posts: 6,140
    I just bought this, https://www.daz3d.com/plant-pots-vol-1 and noticed no forum link, so while I wanted to thank you for a wonderful set, I also want to link to the thread for it.
