Animation: Lowering fps without loosing Frames
Hi,
I have a 33 Frame Animation (all Frames Keyframes) which i set up by accident with 90 fps
When I reduce this to 30 fps the animation is converted to a 11 Frame animation with some interpolated settings.
Is there a way to lower the fps without loosing the Frames so that the animatioon will be three times as long?
just did some testing
in the animate2 time line theres no change in tempo no matter what fps
i think the math is just wrong here
in the daz time line you have to double the fps to make it slower
just another flaw in animate2 you have discovered
but nobody will change this
