whats causing my render so long
i been sitting at over an hour with my render wiht i13 laundry mat and four characters and hdri  on with victoria arribella amadalia and a g3 female running with a 980 ti running what would cause it to take over an hour to render at 7 percent
  • frank0314frank0314 Posts: 15,115
    It's probably the trans maps on the hair. It could also be render setting if set wrong. Are you rendering in Iray or 3Delight?
  • iray
  • Richard HaseltineRichard Haseltine Posts: 111,937
    Is it actually using the GPU? That's quite a busy scene - especially if the characters have clothes and hair.
  • its using up 908  percent ram and cpu at the time and i am runing 24 gigs of ram and running a 3.4 gig quad core i7
  • First guess, you've got too much in the scene for the GPU memory to hadle and it's kicked over to cpu rendering.
    If you mean you've used 90% of your physical ram, at 24gb, then i'd say you are way over the GPU's memory, unless you have a titan with 12gb of ram on it.
    The other thing to be aware of is that iray doesn't show the percentage of render linerarly, meaning that it may sit at 0% for some time, then jump to a higher percentage for some time, then sit at 99% for the remainder.
