I can't run Daz products on Windows 10
Hello, I'm having some troubles to run Hexagon 2.5 (32 bits) and Daz Studio 4.9 (64 bits). Hexagon only shows the splash screen and nothing happens, and Daz Studio only shows up in the Task Manager as a running process but I can't see anything. Then I rebooted my computer just in case and now I get a message saying "has been blocked from accessing graphics hardware''. Here are my system specifications:
OS: WIndows 10 Pro
APU: AMD A10-7850K
GPU: XFX R7 250 with Dual Graphics enabled
Motherboard: Gigabyte G1.Sniper A88X
Ram: 8 gb Kingston
It's a fresh install and I have the latest AMD Crimson driver 2016.0203.1043.19267, the Open GL Version is 6.14.10.13417, I ran a memory test to check the Ram and doesn't seem to have any errors, also Windows is updated and I only have this problem with Daz, other games or graphic design tools work fine but Daz is not running. Anybody is also experiencing this same issue or knows how to fix it? Any help would be appreciated
I am running Daz Studio 4.9 on Win10 with an old AMD processor with a GeForce video card (probably a GeForce 220, but I could be wrong and I'm not at home to check). This is my older computer and I'm using it to test out 4.9 before commiting to it on my newer, faster laptop. Anyway, I have been running DS 4.9 for a couple of months now without problem. However, I think it acted weird the first time I installed it, so I installed it a second time and it worked fine.
I also had the same issue with Poser 11 -- I had to install it, uninstall it, and re-install it before it worked properly.
Sorry I couldn't be of more help.
Thanks, well I was playing around with different configurations until I realized that the problem was with the Dual Graphics, apparently OpenGL and dual graphics aren't working well, not sure if it's my system in particular or if it's a common issue with APUs, but I plugged the screens to the discrete card and turned off the dual graphics. Now Daz works normally, I guess for now I'll keep it that way and only use dual graphics when I need more power until I can figure out a better method. I'll check with AMD to try to solve that issue.
Thank you for your help
Im having this same issue...only trying to install Daz3d.
OS: WIndows 10 Pro 64bit
APU: intel i7-4790 3.6 GHz
GPU: Nvidia GT 730 2GB GDDR3
Motherboard: Asus Z97-K ATX
Ram: 16 GB
I just installed DAZ Studio 4.9 64bit on my brand new laptop , and I may be having a similar problem. But I am running an Intel i7 with a GeforceGTX 1070
the install manager works fine, but when i go to start daz, the program interface appears on one of my screens and then just hangs forever not responding (dual external monitor setup, with the laptop screen disabled).
Asus Strix GL702VS
OS: WIndows 10 Home 64bit
CPU: intel i7-7700HQ 2.8GHz
GPU: Nvidia GTX 1070 8GB
Ram: 12 GB
