Iray Ice Cube
Alessandro MastronardiAlessandro Mastronardi Posts: 2,659
edited March 2016 in Freebies
Since some folks asked, here is the Iray Ice Cube that I used for an image I did some time ago (the mammoth trapped in the ice cube itself).
Link: http://www.alessandromastronardi.com/downloads/iceCube.Iray.zip
The scene it's all set up, with all the needed shaders and geometry. As from nvidia papers, in order to simulate ice properly you actually need to have a surface with some thickness, so a simple flat plane won't work; as you see I used two cubes, one scaled down, to achieve that.
In the original image I scattered around some more bubbles, and used a darker environment and also an HDRI map to get more reflection/refraction diversity.
Cheers
PS: Dumb me: I packed the scene with hard-coded paths so on most systems it may not find the geometry. My bad. So I just created a DAZ Studio compliant product file, and re-uploaded the zip file:
Just unzip where you like: then open DAZ Studio, Content Library, 'add a base library', browse and choose the iceCube folder and then you get the product added to the library.
Sorry for the inconvenience.
736 x 717 - 100K
872 x 901 - 239K
674 x 713 - 283K
Post edited by Alessandro Mastronardi on
