ARGH - Red patch showing up from hair
Gator
The hair is Geneva Hair. I've tried all I can think of, cranking up the adjustments so it's way bigger than the head and not intersecting, turning the cutout opacity to 0 and even then removing the map for it. Also tried adding subd and smoothing modifiers, and then bumping up collision iterations. That spot is still there. ARGH! I've messed around for near an hour on this. Ideas?
1600 x 900 - 313K
Post edited by Gator on
Version of DS and renderer?
Sorry... DS 4.9 and Iray.
Seems to be some weird lighting issue - I moved the character to a different spot, the red splotch went away. Then I even moved the 3 spotlights I was using and it was stil good.
FWIW, the scene has a lot of weak point lights all over simulating torch lights. 10K lumens on them.
