Deforming a mesh using another object
hello everyone.
is there a utility that allows you to warp an object based on the shape of another object?
Example: deform hair based on the shape of a hat , or deforming a sofa
I've always used dform, but I can't create a map using object geometry that affects
753 x 718 - 837K
Utilities that allow you to deform an object to conform to the shape of another object include:
Proteus: Level Set Morphing
https://www.daz3d.com/proteus-level-set-morphing
SimTenero Shape Reprojector
https://www.daz3d.com/simtenero-shape-reprojector
Gescon II: Constructive Solid Geometry
https://www.daz3d.com/gescon-ii-constructive-solid-geometry
Utilities specifically designed to deform hair to fit the shape of a hat include:
SY Hat and Hair Helper Genesis 9
https://www.daz3d.com/sy-hat-and-hair-helper-genesis-9
SY Hat and Hair Helper Genesis 8
https://www.daz3d.com/sy-hat-and-hair-helper-genesis-8
Hat And Hair Helper for Genesis 3
https://www.daz3d.com/hat-and-hair-helper-for-genesis-3
Hat and Hair Helper Genesis 2
https://www.daz3d.com/hat-and-hair-helper-genesis-2
For a manual approach, you can use the Smoothing Modifier. For example, to make a sofa indent when a character is seated on it, you can apply Smoothing to the sofa's mesh and designate the character as the sofa's Collision Item.
Riversoft Art also have products to take care of hairs and hats:
https://www.daz3d.com/hat-check-for-genesis-9
https://www.daz3d.com/hat-check-for-genesis-8
https://www.daz3d.com/hat-check-for-genesis-3
https://www.daz3d.com/hat-check-for-genesis-2
And there is also a free solution for hat and hairs by @mCasual:
https://www.daz3d.com/forums/discussion/309006/get-version-4-mcjhatsarethefashionoftheday-fit-any-hair-in-hats-pc-mac/p1
Based on smoothing modifiers, @matew has Morph Master:
https://www.daz3d.com/morph-master
