Removing Vicky 7:s navel?
Hera
in The Commons
Really stupid question this, but I cannot find Navel Gone for Victoria 7 / G3F. And I've looked all over now. And I have the pro poses. http://www.daz3d.com/genesis-3-female-body-morphs
It's not a navel gone morph you need, it's the navel morph that is on on loading - if you look in the Currently Used group you should see it and be able to zero it.
And how do I find the "Currently Used group"? :)
It should be on the left in the Parameters (or Shaping) pane.
I didn't find it but I solved it another way.
Seems that V3 with her fewer options of shaping has no navel gone option.
Here's a screenshot showing where the morph Richard mentioned is. However, turning it down to zero doesn't completely remove the navel, and turning off limits doesn't really help. Past a certain point (with limits off) it just creates some weird distortion of the mesh. I did a search in the morphs, and there doesn't seem to be a navel gone morph in any of the morphs I've bought. I played around with different combinations of the existing navel morphs, and couldn't get rid of the navel. A custom morph might be needed to accomplish that.
With V7 set and the navel morph zeroed there's no real navel shape if you look at smooth shaded view. However, most textures have some shadow painted into the navel area (or not cloned out of the photo references) so in textured views and renders the area will still show unless you edit the torso maps.
