Import poser
Bonjour à tous;
Quelqu'un peut me dire si Carrara 8.5 a gardé l'import natif et le transposer (importation Poser)
Je travaille toujours sur la version 5.1 pro depuis 2006 et j'aimerais un peu "monter"; mais ce détail est capital pour moi.
Merci d'avance les artistes!
Jean Luc Rostoucher
  • Steve KSteve K Posts: 3,538
    If I understand correctly, you are asking if the latest version of Carrara can import Poser format content.  Definitely yes.  I use Carrara 8.5.1 Pro and routinely load Poser content. In fact, the folders show up directly in the Carrara browser, ready to load and get converted, so no "import" is necessary.  I buy a LOT of Poser format items and have not used Poser itself in a long time.
  • Ah d'accord donc on peut toujours c'est très bien!
    Merci pour votre réponse rapide.
  • therixxtherixx Posts: 263
    Bonjour.
    I also Have Carrara 8.5.1 Pro 64 bit (current version) and I agree with Steve K.
    Not only can Carrara open Poser's stuff from the browser; it can also open Poser scene files like .PZ3 and .PZZ.
    I have some characters whose morphs do not work directly in Carrara (loading from the browser). But if I load them in Poser and save a Poser scene, then I can import/open this scene in Carrara. I made some characters work in Carrara this way.
    You could have problems with new figures like La Femme... I understand these figures have a new weight map system or something like that does not work in Carrara. But I think most of the old Poser format stuff will work decently.
    By the way, if you are planning to buy Carrara, this could be a good moment: it is currently at 85% off
    https://www.daz3d.com/carrara-8-5-pro
  • Bunyip02Bunyip02 Posts: 9,345
    Hello
    Earler versions of Poser models work fine in Carrara. Some of the textures/materials will require a bit of work - have some come in bright and shiny.
    In later versions of Poser - 11 and up (and some Poser 10 models as well) - the models made for those versions will have rigging issues when you try and pose them in Carrara.
  • D'accord merci pour le renseignement. Je suis toujours avec POSER 6.0 VF et pas de souci pour exporter vers Carrara et vue. Seulles quelques coiffures prennent du volume.
