How to fix pleats skirt?
Pleats skirt with a lot of pleats, when used to different chars, the shape change a bit.
How to fix the pleats, so it can get its shape again?
https://prnt.sc/cq84DnrnCcsm
  • Richard HaseltineRichard Haseltine Posts: 111,685
    It needs a custom morph for the shape(s) used, or to use a Rigidity Map to block all  morph projection.
  • JamesJames Posts: 1,191
    edited April 2025
    How to create a rigidity map?
    Can't find it anywhere.
    I can only find rigidity groups
    Post edited by James on
    Sorry, that was what I meant - created with the Geometry Editor.
    edited April 2025
    Okay, I've figured out some things
    I know how to:
    1. make rigidity participant
    2. Make rigidity reference
    3. Apply rigidity weight map
    4. Clear generated morph.
    But somehow the part that I want to keep undistorted, stil distorted.
    What I did:
    1. I selecte the area I want to keep rigid. Assigned them as participant.
    2. I selected few vertices as refrences.
    3. Weight Map the area I want to rigid, 100% red. Basically similar area I want to keep rigid.
    I'm also having difficulty to figure out which morph actually affect that distotrtion, I zero all, but still the skirt is distorted near that vagina area.
    The skirt is for gf8, I use it for G9
    That is probably rigging, is the pose actually zeroed or have you moved the legs together from the zero pose?
    zero pose
  • crosswindcrosswind Posts: 10,322
    edited April 2025
    If you auto fitted a G8F's pleated skirt to G9, by using G8F Clone...., Rigidity Group + Clear Generated Morphs won't work for your case, because that "distorted triangle area" comes from the weight transfer from the clone rather than any full body morph or partial body morph...
    Some ways to fix the issue:
    Step 0: suggest not Auto Fit but load G8F's skirt without fitting into the scene, then dial G8F clone on G9, re-rig the skirt to G9 with Transfer Utility. Zero Clone. In this way, you'll get better initial shape than Auto Fit... (ss 1 ~ 2)
    Ways of fixing:
    - Quickest way: give the skirt a high Smoothing Iteration, export it to OBJ with Base Resolution. Reset Smoothing Iteration, then import OBJ to Update Base Geometry. (ss 3 ~ 5)
    - Add / use dForce to simulate a good shape of the skirt, then Update Base Geometry.
    - Smooth the distorted area in Blender, then Update Base Geometry.
    - Use G8F skirt to "re-fit" on a G9 Base in Blender, then import the skirt shape to Update Base Geometry. This is the perfect way that I always prefer to ~~  (ss 6 ~ 7)
    2560 x 1392 - 631K
    2560 x 1392 - 581K
    2560 x 1392 - 582K
    2560 x 1392 - 569K
    2560 x 1392 - 580K
    2560 x 1392 - 1M
    2560 x 1392 - 542K
    Post edited by crosswind on
    what is  G8F Clone?
    James said:
    what is  G8F Clone?
    In the path of Hidden > Clones...
    2019 x 1291 - 347K
    https://prnt.sc/R-43RZkgFdsq
    I increased the smoothing iteration,  but in my case, the triangle distortion didn't go away.
    Which product are you using ? or you made this skirt with MD or sth. ?
    edited April 2025
    dForce HnC Pleated skirt outfits for genesis 8 females
    The culprit : Smoothing Type on this skirt is set as Generic, change it to Base Shape Matching. (ss 1)
    Besides, another trick: when re-rigging the skirt to G9 (with G8F clone dialed..) with Transfer Utility, check the option: Use Adaptive Tolerance and set it as 100%. (ss 2 )  It'll help with lessening the distortion significantly. (ss 3 ~ 4)
    2560 x 1392 - 882K
    2560 x 1392 - 902K
    1424 x 1294 - 568K
    1424 x 1294 - 570K
    Okay, it works, thank you.
    NP!
