Dress is sticks out to the sides
nimonsi_5039111nimonsi_5039111 Posts: 65
edited April 2025 in New Users
Hello, when I put a dress on a character, it doesn't hug the body but sticks out to the sides. Help me solve this problem? I've tried the compatible version, both Gen 8 and Gen 8.1. Thanks!
https://ibb.co/DPrdkWT5
Post edited by nimonsi_5039111 on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    That is probably a dForce dress designed to be simulated - try clicking the Simulate button in the Simulation Settings pane (once the figure is posed, assuming there are no body parts intersecting and that it can get to that pose without anything crossing through itself - if not soem tinkering may be required)..
  • I did the simulation and i tried different dresses, but got this
    1153 x 817 - 66K
    Is it a dress made for the figue you are using it on? Which dresses are you using - generally they will have dForce in the name if they are meant to simulate.
  • yes, it's for 8.1, and i have a 8.1 figure
    this is another dress
    I have another one and it's works ok, i can work it with a little adjustments, but this are two are just crazy
    1274 x 797 - 78K
  • felisfelis Posts: 6,502
    Which dress is it?
  • ElorElor Posts: 4,101
    edited April 2025
    In the simulation settings, you can try changing the collision mode from Better to Best: when I had similar problem (dresses falling inside the character), it solved it. The simulation will take longer though.
    Do to that, open the Simulation settings panel and select Best:
    If you don't see the Simulation Settings panel, you can make it appear by going to the Window menu, then Panes (Tabs) then click on Simulation Settings:
    524 x 789 - 65K
    809 x 1049 - 157K
    Post edited by Elor on
