Tonemapper Options and Environment Options gone from Render Settings
I'm hoping someone can help explain something weird;
I used to get both Tonemapper Options and Environment Options appearing in the render settings tab. Now they don't. They are in the scene, and I can edit them through the Parameters tab.
Is there a way to put them back in the render settings tab, as it was easier to work?
This change happened around the time of fillatoon. Not sure if related.
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    They should appear in the Render Settings if you have the nodes in the scene (but not before)
  • jkjjkj Posts: 27
    They used to! But they're not there anymore. I tried show hidden properties, but no good.
  • jkjjkj Posts: 27
    Oh  wow! Just discovered something. I switch "engine" from Iray and back. And they're there again!!
    Odd, I wonder if something else interfered with refreshing the property list - I don't recall encountering that (but I have tended to use the ebta version, not the General Release).
