Solved: Diffeo - Material Editor throwing an error
DrGonzo62
Hi,
I tried using the Diffeo Material Editor (BL 4.3.2) on a G8M mesh and I'm getting an error when I try to update the materials:
AttributeError: 'Material' object has no attribute 'DazSlots'
Is that a bug?
Thanks!
(I've searched here and didn't see a post about this issue.)
Post edited by DrGonzo62 on
OK, never mind.
Seems that there is something with this particular G8M that the material editor doesn't like.
A stock G8 works fine.
If you tried to use the diffeomorphic tools on a figure imported with another addon then it doens't work, because diffeomorphic adds metatadata that's missing if the figure is imported otherwise.
