Daz similar style dress?
in The Commons
Would anyone know if Daz has a dress similar to this?
There's this: https://www.renderosity.com/marketplace/products/154067/d-force-knitted-dress-2-for-g8f-g81f but it's shorter and for G8. if that matters.
Almost but want something form fitting like that that runs below the knee to the calf. Thanks!
The closest I have in mind is this one but it cut on each side over the knees:
https://www.daz3d.com/dforce-autumn-breeze-outfit-for-genesis-8-females
I found something pretty much exact but would love a more refined pro level of design that comes with Daz products. I used a shader add detail. Thanks!
Just a tip that if you want that body-hugging look, you can really add it to any dress by adding a dForce modifier to it and setting the Contraction/Expansion ratio to less than 100. Anything less than 100 is contraction, so it shrinks the material more and more as you lower the value.
Personally, I start off at 98 and gradually lower the value until I reach the point where it hugs the body in a pleasing way.
I'll try that. Thanks!
