Possible to teach DAZ Studio to use a standard render setting and not the settings saved in Files
snmherosnmhero Posts: 1
edited April 2025 in Daz Studio Discussion
Hello, I've been rendering exclusively with the CPU for two years and had a GeForce 1030 as my graphics card because I wanted to try out DAZ. When I first started with DAZ, I built a PC from leftover parts since I'm generally a laptop user and don't play games much. Now that I've taken a liking to DAZ, I was able to get a 16 GB graphics card from a friend for a good price, and now I have a question... Is it possible to teach DAZ Studio to use a standard render setting and not the settings saved in the file? Since the GPU can render everything faster and, above all, better than the CPU, I'd like to re-render a few projects. So far, the CPU has rendered 100 to 250 frames, and then I've run a denoiser over them, which is clearly noticeable in the quality. I don't want to open all the files, adjust the render settings, and then save them again... Is there a way to do this in DAz, or perhaps a tool? Thank you very much. I hope I explained my problem clearly.
(Edited by mod to remove code style format for the post)
Post edited by frank0314 on
  • barbultbarbult Posts: 27,501
    edited April 2025
    Key shortcut F2 Preferences then on the Scene tab, tell it to ignore render settings on load. I am running 4.23.1.44 Public Build (Beta). Depending on the version DS you are using, you may not have that option. I don't remember when it was added.
    Or, you could save a render settings preset that you prefer and apply that preset after every scene you load.
    789 x 706 - 66K
    Post edited by barbult on
  • snmherosnmhero Posts: 1
    Hey barbult
    oh dear, so easy and I overlooked that :-O I try it :-D
    Thank you very much!
    I hope it works well for you.
