Help finding content to install using Connect
KharmaKharma Posts: 3,214
So far I have tried installed one product with Daz Connect..the encrypted cozy bed , worked fine, installed, loaded. rendered, no issues. Now I have already installed Genesis 3 male and female starter essentials via DIM, but now wanted to install the G3 head and body morphs through connect but I can't find them in the products section of smart content. I am in the products tab and have all selected and filter by context off and have G3F loaded in the viewport, but no head and body morphs show up.  I have tried typing morphs in the search bar and they don't show up, what is the procedure to find them? If I go to the products in Content Library they do show up there, but that's not the point...the smart content tab is supposed to show them and I don't find them anywhere
  • I don't see them in the Smart Content> Products list, but I do see them in the Content Library>Products>G list. I don't know whether that is by design or an error in the metadata, but it may be worth opening a support tcket to report it.
  • KharmaKharma Posts: 3,214
    I did finally manage to find them under products but only if you have all selected at the top on the left pane and at the bottom of the right pane and have filter by context not checked, but I would think they should show up if you had the folder people checked or shaping or something like that
    Part of the issue is likely that the head and body morphs don't actually show up in smart content after installation since they're morphs that just become dials on the figure parameters.  (A possible solution Daz may want to try is including a reset pose with the morph packages that sets all the included morph to zero and provides a single bit of content that can be categorized so the product is under shaping)
