Imported Cloth from Marvelous Designer into DAZ. Cloth appears stretched and clipping on Character.
The shorts I designed and imported from Marvelous Designer into DAZ appear stretched and clipping through the character, even though I made the character in DAZ and used it in MD when designing the shorts So they should perfectly fit the character. Does anyone know how to fix this?
2559 x 1368 - 744K
  • Richard HaseltineRichard Haseltine Posts: 111,666
    If the clothes are made to fit a non-zero shape then DS will not know that and will assume that they are meant to be shaped as theya re relative to the base, then it will project any morphs used into the clothes. If you select the Reverse Source Shape from Target option in transfer Utility (and either seelct the shape used or Use Current) then the clothes will be anti-morphed to fit the base, but it is better to make things around the base shape if possible.
  • I don't know why the image did not show up, so I'm posting it here. This is after I used Transfer Utility on it. I tried to select the Reverse Source Shape from Target option, but for some reason I can't select it. Do you know why?
    2559 x 1368 - 744K
