Victoria 4.2 base in 4.9 pro issues.
does anyone else have victoria 4.2 in daz 4.9? and if so does it work? I have tryed everything and mine simply will not show up, it's in the list, but simply a box with a triangle in it, says file not found. Ive reset everrythong, reinstalled several different times, and even redownloaded it and installed it again, it just doesnt exist apparently.
Has anyone else came across this and knows what to do? I bought some content based on victoria 4.2 base, and i cant use any of it.
  • KhoryKhory Posts: 3,854
    If your getting boxes then your missing files. My bet would be that your data for v4 did not get installed properly. I suggest a reinstall of the product.
    How did you install Victoria 4.2 base?
  • Launch the DIM and check to see if it available in the "Download Files" tab, if not, you may need to the "Installed" tab and find it to uninstall, then reinstall from the Download tab.
  • RowanessqueRowanessque Posts: 147
    Thats how did it, go through products found Victoria 4.2 and then install her with DIM she should show up in Content, Smart and have a look in the file called "LostFound" loads of stuff in there that you forgot you had. xxx
  • GreybroGreybro Posts: 2,705
    I notice that the V4 base a nd M4 base seem to be the only ones that do not show up in Connect. Seems odd when 3.0 for both figures shows up as does Michael 1. Are we supposed to switch over and use DIM to install those? That seems inefficient and like a mistake honestly.
    None of the 4th generation characters...Aiko4, Hiro4, Freak4, etc will show in Connect.  It's the way they need to be installed so their morphs work that prevent Connect from being able to install them.
    ...currently
    ...currently
    Hopefully not too much longer...
  • Actually now, I have the same problem V4.2 has disappeared and the DIM fails to reinstall every time.
    What exactly happens when you try to reinstall with DIM?
  • What exactly happens when you try to reinstall with DIM?
    "Install Failed". It downloads just fine, but fails to install.
    Does the DIM log give any details?
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • If you choose to Work Offline in DIM it won't care about the age of the package (as long as it is a DIM zip). Of course using an older version when there is an update available is probably not a good idea, and if you need support you will be told to update first, but you should be able to do it if you wish.
    The gen 4s cannot be installed by Connect due to their ExP morph system that requires all morphs to be install to the same library folder as the figures.  Connect creates a separate folder for each product it installs.
    Anyone care to tell us how this is done or point us to a link that gives us step-by-step to accomplish it this way?
  • rumpotrumpot Posts: 96
    edited March 2017
    This is still an issue in Connect. The base is not showing to d/l. Do we install manually, if so where?
    btw here http://www.daz3d.com/forums/discussion/65115/v4-2-and-m4-not-working-in-4-9
    #2 points to here
    http://www.daz3d.com/forums/discussion/comment/932652/#Comment_932652
    Page Not Found
    The page you were looking for could not be found.
    that is missing
    Post edited by rumpot on
    USE DIM!!!
  • I downloaded victoria 4.2 base bundle. I can find everything but the character. I looked everywhere known to mankind for figure to no avail. Should I just chalk it up as a loss?
  • Okay, the second after I posted this I lovely Victoria. Can I move her into my smart content?
  • Disregard, found that too. Sorry to be a pest.
