Lost and Found files
What is the Lost and Found files/products group?
How do I get them into the right categories?
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Lost and Found should be things that didn't otherwise have a category. You can right-click>Categorise on files or folders, or if you want to do a more thorough job (adding compatibility and type, assuming those are also missing) you can select what they should be compatible with (e.g. the base Genesis figure)  and drag the file(s) into the desired category in Smart Content, then seelct the type (e.g. wearables) in the diualogue that pops up. Then you can load and select the item and do the same with its materials, and so on.
