Getting Headshop PRO 2023 to work. What's the secret??
katherine_4a0d2c0d5e
Headshop Pro 2023 is not working for me.
I installed it in the C:\DAZ3D\Applications\64-bit\DAZ 3D folder.
I copied the Libraries, Models and morpher directories into the Headshop plugin directory.
In DAZ 4.23, I load a Genesis 8 female figure.
I start Headshop. I select Restore for the Zero Figure.( Have also tried Zero )
I select Genesis 8 and Female. I load a face photo. I hit Apply
I get the dialog box message: Unhandled exception has occurred in your application. If you Continue, the application will ignore this error and attempt to continue.
If I hit Continue I get File/Front_Tab_AutoSculpt_Tab etc. dialog box with a big red X on the left.and a Please Wait indicator.
And the Please Wait goes on and on.
So, what’s the secret to getting Headshop PRO 2023 to work?
Any insights will be greatly appreciated,
--Katherine
Hi Katherine,
you guessed; the secret was to email Abalone tech support, thanks for doing that.
We solved your install problem same day.
Thanks again for contacting us at [email protected]
