Poser Formats seems unorganized, is there a way to fix
XaatXuun
not sure how to say it
but when going to poser formats, everything are listed just in numbers, after the numbers things look normal. Making a very confusing and messed up " I don't know what is there" moments
is there a way to have it better organized , like it used to be
eta: forgot to mention this only happen because that's what DAZ Connect did, any manual installs everything is normal,
I would just move the content to the correct order, but have no idea where DAZ Connect placed them, looks weird where it did
Should I just copy out of that awkward cloud folder
691 x 493 - 57K
Post edited by XaatXuun on
Those are items installed using Daz Connect. You should not see those folders at all - they are in the Data folder and the Data folder is hidden. You cana ccess them proeprly through the Products list under Poser Fromats, where they will be listed in name order, or in Smart Content. Alternatively you can install with DAZ Install Manager instead, which will consolidate all the items into one content folder (though they will still be split by the Poser library types).
oh well, manual installs then . . not a fan of DIM, it's always been messed up for me
your reply was appreciated, just not happy with it
