Dforce weight node modifier doesn't paint
I haven't tried this in a while (years actually) so maybe forgetting something...
All the bits are added and think I'm in the right place but paint brush won't paint - what am I missing?
Screenshot attached
Any help appreciated
1880 x 681 - 95K
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Does the plane actually have divisions? Weights go to the vertices.
  • crosswindcrosswind Posts: 10,354
    edited March 2025
    Even if the plane is with 1 division, paint brush should work on it.... It seems that the primitive plane is already fully weighted (that's the default behavior when you add weight map to the dForce weight node..),  you can increase Sensitivity, hold Alt key to paint, see if you can remove the weight. Be noted, you have to drag to paint for some time... (ss1)
    Edit: Or select all polygons, fill zero weight firstly, than paint the weight as usual, see if it works. (ss2)
    2560 x 1392 - 353K
    2560 x 1392 - 354K
    Post edited by crosswind on
  • WouldheWouldhe Posts: 40
    I'd guesed it was the removal element I needed but was struggling on that - ALT key solves - thanks for that!
