DAZ Connect Moving Files
I am still trying to get my head around how I move DAZ Connect files off my c:/ drive? My root c drive is almost full and I do not want to to install anymore content on it! I have a H:/Drive called My DAZ 3D Library which I now put all my DAZ content in. Can I safely move the DAZ Connect files to my H:/ drive if so what do I call it? Also where do I find the Daz Connect files? Cheers
    In DS go to Edit > Preferences > Content Library > Content Directory Manager, expand "Daz Connect Data" and change the location to your desired location.  Then close DS and move the old files -- the default location is C:\Users\Public\Documents\My Daz Connect Library, move the Data folder from there and merge it with the Data folder in your new location.  You can use the same My Daz 3D Library.
  • If you don't want to mess with configurations, you can also set up a symbolic link between your C: and your D: for that specific folder (especially if you're used to working in that folder already).
    Though I like I said, that's only if you didn't want to reconfigure it. I am apparently a weird sort of lazy.
