How do you select the skydome?
Kev914Kev914 Posts: 1,143
I watched a video by SickleYield where she sets up and lights a sifi scene. I've watched it a number of times and I think she selects the skydome in the scene list and then adjusts light settings, etc. for it. But I don't ever see the skydome in my list. I have it set to dome and scene. Some times I think that maybe what she selects is some object in the sifi set, but there's a part where she zooms in on the sky dome and you can see it in the workspace, so I think she selects the sky dome.
Also, I wonder why she can see the sun settings etc, but I only have a short list under environment. I have show subsets checked. I have a list of many 10 or 15 items, but SickleYield has a whole column. Could it be that things changed since the beta? I believe that is what she was using in the video. I'm pretty sure she said to set it to dome and scene, so why does she get so many settings.
She adjusted some light settings, like emission temperature,etc, while the skydome was selected. But I don't get those settings unless I add a light. (I can get more settings if I select the sky choice.
Thanks.
  • AJ2112AJ2112 Posts: 1,417
    In render settings > enviroment or dome > draw dome, to tun on/off.
  • I have the worst luck with skydomes
    I currently just render a shot with only the dome, turn it off, render scene then layer them together in PS
  • BartlebyBartleby Posts: 58
    edited February 2016
    I don't know which video you are looking at, however if she is selecting the sky dome from the scene list I suspect she is using a sky dome prop.
    But as far as I know you can't select the iRay dome from the scene list.
    [edit] or as you suggest, could be a change from the beta.
    Post edited by Bartleby on
  • RafmerRafmer Posts: 564
    Sounds as she could be using the Iray Worlds Skydomes product by your description.
  • Kev914Kev914 Posts: 1,143
    The video is here....
    I think it about midway through. Perhaps the skydome isn't the "Daz" skydome, but a skydome that comes with Stonemason's SiFi architecture.
  • FishtalesFishtales Posts: 6,231
    That is the Skydome that comes with Stonemason's set.
    Thanks for your help!
