Object Geometry is displaced
jmucchiellojmucchiello Posts: 2,612
I have a prop whose translation values is 0,0,0. But the actual position of the object is 400,-10,-3332. Is there a way to permanently fix it's location to 0,0,0. I could put it in a group and position the group at -400,10, 3332. But that doesn't make moving it around any easier. When I see 0, 0, 0 in the parameters panel, I want it actually be at 0,0,0.
Solutions involving external 3D programs while appreciated also are not helpful.
Tilte edited by mod
  • Richard HaseltineRichard Haseltine Posts: 111,984
    If the item is modelled off centre then it will be off centre when its transforms are zeroed - usually this is because it was made to fit into a larger set. For a static item put it in the middle of the scene, export as OBJ, reimport, and reapply materials.
