"Daz could note find the 72071 product"
rustajrustaj Posts: 39
I bought Skies of Economy Redux Volume 1, I'm able to see it in DazCentral and Daz Install Manager, but when I install in either, it never shows up in Daz itself. Has anyone come across this before?
I got an error log message "failed with exception: ERROR:  duplicate key value violates unique constraint "product_guid_key"
DETAIL:  Key (guid)=(a0230ba2-4ee9-42f1-ac0e-aaf83d897a13) already exists"
I have Skies of Economy Volume 1 Lite that does appear in Smart tab, but I don't know if that's relevant to this issue.
Post edited by rustaj on
  • NorthOf45NorthOf45 Posts: 5,896
    The Lite one is just a small subset of the full version, given free as a promotional item. You can uninstall Lite and use the full product, you will not lose anything. Odd that the GUID is the same for both, though. That is the primary key (which cannot be duplicated) used to uniquely identify products.
  • rustajrustaj Posts: 39
    Thank you for the insight!
    I think what's throwing me off is all volumes of the Skies of Economy are in one folder (Vol 1 - 4+ represented as 1-32 files). So I've deleted the Volume 1 - Lite, but when I go into the folder I see the full set of Volume 1 (1 - 8) with Volume 2 starting at 9. But when I look through Smart folder it only shows the options to install the Lite version of Vol 1.
    Deleted, or uninstalled? Uninstalling will also remove the metadata used by Smart Content, deleting will only remove the content.
    Wait. You would not be able to install the full product if the Lite version was still in the system, so I am presuming it was uninstalled. The library just might need a refresh, sometimes fresh products don't show up properly.
