How to fix G8 mouth abnormality(Resolved)
AsuCafeAsuCafe Posts: 560
Some G8 Figures will appear strange on the mouth when applied on G8.1, For example, like "CO Reine and CO Reine Hair for Genesis 8 Female(s)", the left side is the original G8.0, and the right side is applied in G8.1, how to fix it?
640 x 480 - 26K
Post edited by AsuCafe on
  • CES3DCES3D Posts: 254
    Please check the Currently Used parameters of Genesis 8.1 Female and remove any interfering morphs.
    For CO Reine, set the following four morphs to 0%.
    • eCTRLCOReineLipsPart
    • eCTRLCOReineMouthSmile
    • eCTRLCOReineMouthSmileOpen
    • eCTRLReineMouthFrown
    2560 x 1400 - 1M
    2560 x 1400 - 1M
  • crosswindcrosswind Posts: 10,334
    edited March 2025
    Because the character was designed for G8F and the controller expression properties ( at 2nd Stage in ERC link... ) for some of the corrective morph of this character are blocked by G8.1F as default.
    I'd recommend a once and for all solution: remove the dummy blockers by checking this post: https://www.daz3d.com/forums/discussion/comment/8833706/#Comment_8833706
    Then reload G8.1F, the corrective morphs won't be auto-dialed.
    2560 x 1392 - 768K
    Post edited by crosswind on
  • AsuCafeAsuCafe Posts: 560
    It works, thank you.
    I will try, thnak you.
