Clothing Converter from Genesis 3 Female to Genesis 8 Female not working fully
Looking for some help with [Clothing Converter from Genesis 3 Female to Genesis 8 Female] the above utility, I have attempted to use this on a number of genesis 3 female clothing items and it appears to work without generating any errors.
However when I close daz and then re-open it to test the new genesis 8 version, despite it having created a new duf file in the genesis 8 clothing directory when I select the item and attempt to merge this onto a genesis 8 female figure i get the attached error regarding missing dsf files?
txt
txt
log file.txt
2K
833 x 965 - 51K
Please don't post images showing textured, nude figures. Please do make sure that the body of your post ciotnains all the information (not refering back to the thead title etc.)
What are your content directory settings (Ediut>Preferencs, Content tab, Content Directory Manager)? What does the DS log itself say after trying to load the file (Help>Troubleshooting>View Log File)?
Please see attached content directory settings and the DS log file.
Thanks for your help
Can you load the shirt yoy are trying to convert?
The log says it can't find it.
I can try and load the shirt as it has created the duf file for it in the genesis 8 female clothing directory but it fails due to the missing dsf files.
But can you load the original shirt?
Yes it loads fine onto a genesis 3 female and using auto follow onto a genesis 8 female
This product I assume https://www.daz3d.com/clothing-converter-from-genesis-3-female-to-genesis-8-female
If so, you could post in the commercial thread https://www.daz3d.com/forums/discussion/340346/released-character-converter-from-genesis-3-female-to-genesis-8-female-now-conv-jcms-commercial/p33
Riversoft is usually active.
Thank you for your help
