Rigging an A Pose garment to a T Pose Genesis figure.
WilmapWilmap Posts: 2,917
Is there any way to rig an A-Pose garment to a T-Pose Genesis figure?
I have made a garment in the A-pose as it drapes sleeves better, but I can't get the bones to follow the arms in the dress. Is there a way to do this or not?
  • KarenKaren Posts: 110
    edited February 2016
    You could try to use Transfer Utility with Item Shape set to Current.
    I know that I will run into the same problem sooner or later ;-) so it would be nice to hear if it works.
    Edit: Sorry, forgot to mention that Figure should be posed in A-Pose, too. After using the Transfer Tool, pose Figure back to T and the sleeves should follow (theoretically)
    Post edited by Karen on
  • RufusdazRufusdaz Posts: 1
    I tried modelling a garment onto a posed Daz figure then importing it back to the posed Daz shape. It fit no problem, when I use the trasfer utility  to conform it, it deforms. I tried changing the Item Shape to 'current' but no luck. The tranfer utility only seems to work on the Daz default T-pose. It's a bummer because its not a good pose to model realistic clothes onto. If anyone knows of a way I can do this pls reply . Cheers
