Issue with Importing DAZ Environment into Unreal Engine
mohamazaouimohamazaoui Posts: 0
edited March 2025 in Unreal Discussion
Hey everyone,
I'm having an issue when importing an environment from DAZ into Unreal Engine. Every time I import, a new level is automatically created instead of adding the environment to the default level.
Is there a way to import environments without generating a new level each time? I’d like everything to be added directly to my main level.
Thanks in advance for your help!
  • Richard HaseltineRichard Haseltine Posts: 111,937
    Moved to Unreal Discussions, where it is more likely to be seen by those who may be able to help.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,769
    I just don't use the DAZ 2 Unreal plugin wink
    no real advantage with sets
    obj export works pretty well on stuff without instances
    the latter I use the Code55 instances to objects script on first
    some environments are more difficult, if they have Ulrascatter, just don't bother with that foliage, import the foliage separate and use Unreal's tools to brush it in, add a simple wind material etc
    occasionly one gets a parented set that explodes on export, those you need to fix in DAZ studio first, unparenting in place
