Using PTF Grungy Threads
Hello. I want to ask for some help in applying the blood stains to clothing. I'm very new to using Grungy Threads and am not sure how to apply them or if the clothing my models has on is compatible to it.
  • You need a geoShell on the item to apply the dirt layers too or you need the item and the surface(s) you want to modify selected before aplying a Layered image version. If you look at the files in the content Library pane, rather than a categorised view like Smart Content, then as I recall the foilder structure will help make things clear (if you are in a category view right-click on one of the files and from the Show  Asset sub-menu choose the Mapped or Virtual folder; which you get depends oin installation method)
  • sidsid Posts: 588
    Under utilites using the SmartContent view there's also a set of scripts that if you double click on them will give you instructions with pictures
    2407 x 1229 - 268K
  • NorthOf45NorthOf45 Posts: 5,915
    Several older threads about PTF Grungy Threads:
    PTF Grungy Threads results
    ptf grungy threads
    Question about PTF Grungy Threads
