Shader Preset on wrong side of object
myotherworldmyotherworld Posts: 664
edited February 2025 in The Commons
OK so this is a new one for me, But here goes.
I have inported a Poser architectural figure into daz and want to change the windows
From a glass to an Iray Shader Preset texture.
The Problem is the texture is on the out side of the building. The inside has a pink colour to it?
Is there a way to flip it so that the texture I want is on this side?
The model is not ment to be seen from the outside, its an inside job only.
Dont know if this is understandable but fingers crossed
Post edited by myotherworld on
  • TotteTotte Posts: 15,098
    Surfaces do not really have sides (unless you have a special shader), so you probably have another piece of mesh on the inside. Pink from Poser content usually means it's mc5 or mc6 type of Poser shader tree materials that DS has no knowledge about at all. So, find the surface on the inside, as you said this is an exterior set, the inside "pink" was probably a reflective surface using poser shader tree.
    Post edited by Totte on
  • Thanks. But I have sorted it. I was rendering with head light off and no lights in scene.
