File check with DIM
EddyMI3DEddyMI3D Posts: 365
edited February 2016 in The Commons
Hello, I found out, that some packages lost some files.
Is there a way that DIM can check this and repair the damaged packages?
Or do I have to install all files/Packages again?
Thanks in advance, Eddy
Post edited by EddyMI3D on
  • DIM won't do that, Daz Connect will (it should show the product as having updates, which will be the missing filesm, as I understand it). As long as you didn't delete the zip uninstalling and reinstalling should be quick. However, are you sure it's missing files from a product and not missing the base files needed for a separate support product?
  • frank0314frank0314 Posts: 15,090
    Before uninstalling and reinstalling, rt click on the pack name and select "Show Installed Files" to be sure you aren't over looking something. If you aren't over looking it then go to your install tab and select everything, rt click and select "Re Import Meta Data".  If that don't work then you will have to uninstall that pack and reinstall.
