OOT's dforce SBH doesn't simulate
bought the Voluminous Wavy Bob Hair Strand-Based G8 by OOT a while ago and couldn't get a working simulation for this hair product.
So I downloaded it again and hope the issue might be fixed by now, but NO.
The simulation works fine on G9, but not on G8 as promised in the product description.
Hope to have G8 dforce simulation for this hair soon.
https://www.daz3d.com/dforce-strand-based-voluminous-wavy-bob-style-hair-for-genesis-9-and-8-female
  • It dosn't seem to recommend simulating anyway. What happens when you try with Genesis 8, as opposed to Genesis 9?
  • Simulation works with G9, with G8 it does not work.
    With only G8, I get an error message, that there is no simulation item in the scene.
    The advertisment clearly indicates, that I can have a dForce simulation with the G8 version.
  • And this is the Genesis 8 hair, which has G8 at the end of its name, not the Genesis 9 hair (which isn't labelled) converted to Genesis 8? It appears to be set to be dynamic, and I don't get thaty error (I do get a failure, but I think that is driver-related).
  • MasterstrokeMasterstroke Posts: 2,486
    edited February 2025
    No, it is not converted to G8.
    It has been advertised as dforce hair for G9 AND G8F
    The product headline reads:
    "dForce Strand-Based Voluminous Wavy Bob Style Hair for Genesis 9 and 8 Female"
    Post edited by Masterstroke on
    from the shop page (free to see for everyone, I guess):
    • dForce Strand-Based Voluminous Wavy Bob Style Hair for Genesis 9 and 8 Female: (.DUF)
    • dForce Strand-Based Voluminous Wavy Bob Style Hair for Genesis 8 Female
    From the readme:
    dForce Strand-Based Voluminous Wavy Bob Style Hair for Genesis 9 and 8 Female (Core)
    • You can find new icons for loading this product in the following DAZ Studio Folders:
      • “People:Genesis 8 Female:Hair:OOT Voluminous Wavy Bob Style Hair:Strand-Based”
      • “People:Genesis 8 Female:Hair:OOT Voluminous Wavy Bob Style Hair:Strand-Based:MATS:Base”
      • “People:Genesis 8 Female:Hair:OOT Voluminous Wavy Bob Style Hair:Strand-Based:Presets”
      • “People:Genesis 8 Female:Hair:OOT Voluminous Wavy Bob Style Hair:Strand-Based:Utilities”
      • “People:Genesis 9:Hair:Out Of Touch:OOT Voluminous Wavy Bob Style Hair:Strand-Based”
      • “People:Genesis 9:Hair:Out Of Touch:OOT Voluminous Wavy Bob Style Hair:Strand-Based:MATS:Base”
      • “People:Genesis 9:Hair:Out Of Touch:OOT Voluminous Wavy Bob Style Hair:Strand-Based:Presets”
      • “People:Genesis 9:Hair:Out Of Touch:OOT Voluminous Wavy Bob Style Hair:Strand-Based:Utilities”
     and in the file list there is
    /People/Genesis 8 Female/Hair/OOT Voluminous Wavy Bob Style Hair/Strand-Based/Voluminous Wavy Bob Style Hair Strand-Based G8.duf
    so chances seem to be high that it really is a G8F based hair
  • I know it is for both, but it isn't the same file for both - there are two hair models and you need to use the one for the figure being used.
  • barbultbarbult Posts: 27,479
    Some vendors use identical thumbnails for both hair files (G8 and G9). In Smart Content, it is easy to click the wrong one, because a user can't tell which is which just by looking at it.
  • crosswindcrosswind Posts: 10,245
    Yes, so I had to frequently go to the mapped folder in Content Lib to add a suffix of G3/G8/G9 to the user-facing files.
    Post edited by crosswind on
    Yes, I could reproduce the issue. This issue ever happened to another hair from them IIRC. I got the same issue when converting SBH from G9 to G8 by using various ways... Especially, with the way of FixBase + Re-rigging, I got dForce modifier work with no issue at the first place. After saving figure asset and reload the hair to G8F, I got the same error and couldn't simulate it again ~~
    2560 x 1392 - 452K
    2560 x 1392 - 535K
  • 3DSaga3DSaga Posts: 895
    But the OP shouldn't have to go through extra steps to get the product to work as advertised, should they? Wouldn't this be an issue for DAZ Technical Support to address?
  • chevybabe25chevybabe25 Posts: 1,346
    That sounds like a broken dforce hair modifier and can only be fixed by the PA.
  • crosswind said:
    Yes, I could reproduce the issue. This issue ever happened to another hair from them IIRC. I got the same issue when converting SBH from G9 to G8 by using various ways... [...}
    Again, I did not convert anything.
    This hair procuct add says: "Dforce hair for G9 AND G8F"
    No, I didn't mean that you converted it.
    I mentioned conversion because there's a way of converting a hair made for a certain Genesis to another.... that I ever learnt the method from other PAs... so it might be one of the culprits I presumed.
    and we are asking which of the two files ypui are using - pointing to the product page doesn't answer that. it does, however, seem that there really is an issue with the Genesis 8 version.
  • I am having problems with the G8 version of the hair. The G9 version does simulations.
  • 3Diva3Diva Posts: 12,058
    A support ticket would probably be your best bet of getting it resolved. I don't know if either OOT nor the Daz Support people frequent the forum (likely not). So putting in a support ticket might be the only chance of getting it fixed.
