How to save tiling from Image Editor?
Hi! In the normal map image editor, I used a specific value for tiling, different from the general tiling value, and I would like to save this value as a shader preset. Is it possible to save specificly the tiling from the image editor, without saving other presets?
In the Shader Preset Save Options, I seached for the normal map, but I didn't find anything about its own tiling, only about ist value and image... Amn't I in the right place?
Thank you in advance for your help!
«1
  • I don't think it is possible to save the tiling, which is an image property, without the image.
  • yuyu.atemyuyu.atem Posts: 497
    edited February 2025
    Ah, ok, thank you very much! I guess it is the same for saving separately a specific layer in a layered image editor, isn't it?
    It's too bad... indecision If I may make a suggestion, I think that it could be a good improvement for a next version of DS...
    Edit: I just created a post about it in the Product Suggestions topics.
    Post edited by yuyu.atem on
  • A Layered Image preset should allow you to save out layers - that is how things like presets for makeups are saved. But it would be the whole layer, I don't think you can save out some settings on the layer for use with different maps on the layer.
  • crosswindcrosswind Posts: 10,351
    What you set in the Shader Preset Save Options is correct. Just go ahead. The Instance Tiling data you set in Image Editor will be saved in the preset file, as image_modification, rather than the whole surface Tiling.
    Saving Instance Tiling needs both Image and Value options selected... Though you can delete the code line of texture map in Shader Preset DUF file, there still needs to be a texture map in Normal slot before you applying the Shader Preset, otherwise Instance Tiling won't work.
    Post edited by crosswind on
    You cannot select a target layer when saving LIE Preset other than Surfaces with LIE(s), but you can define and save LIE Preset layer by layer. Or, after saving the preset, you can easily delete the layer(s) that you don't need in LIE Preset DUF file, by using Notepad++, etc.
    Technically, I think it's possible to realize the feature you need from development perspective... it'll depend on how development guys think about it. devil
    Thank you very much! I openned the duf file in the Bloc-Notes app, but the entire code seems to be in Chinese:
    Is it normal? How can I indentify the line of texture map in the code?
    Thank you in advance!
  • LeanaLeana Posts: 13,632
    The preset is most likely compressed, you would need to un compress it if you want a version readable directly.
    I think there's an action for that in DS, or you can use a compression program like 7zip for example (compression used is GZIP)
    Ha, they're not literally meaningful Chinese but just compressed code.... In DS, you can uncompress the file via: Windows  > Panes > Batch Convert.
    Or, when you save the preset, uncheck the Compress File option  ~~
  •  Thank you very much! laughI am a bit lost in the code, should I delete these lines?
    Or maybe some of these ones?
    The only par where I find information about tiling is this one:
    Yep, simply delete the coding block as shown in below screenshot. Then, again, make sure there is a texture map in the target Normal Map slot on which you want to apply this preset ... otherwise it won't work.
    1700 x 534 - 44K
  • Ah, ok, thank you very much! If I understand well, I don't have to delete the blocks shown in my two first screenshot (the "Image_library" and "material_library" blocks"), only the block framed in red in your screenshot, is it that?
    That's right, you don't have to delete them. In this sort of cases, the principle is : necessarily doing the minimal deletion will be just fine.
  • Ah, ok, thank you very much! laugh
    Oh, I forgot to ask: for now, I saved my files without compression in order to modify them easily, but if I want to compress them after that, should I just use these settings, without checking or unchecking any case?
    That's correct.  Just tick Compress Listed Uncompressed Assets, as you did in the above screenshot. Then add the DUF files or folder. Apply.
  • Ok, thank you very much!
    I have another question about the instance tiling in the image editor and the whole surface tiling: let's imagine I set a non integer value in the image editor (ex: 2.33), and a value > 1 in the whole surface tiling (ex: 4), could it create seams even if I am using a seamless map? What are the priorities in tiling? Is the map first repeated according to its instance tiling and then, according to the whole surface tiling ? In my example, I have the impression that it would generate 4 seams, because the 2.33 in the instance tiling would generate a "global map" not seamless.
    Well, that'll depend on the UV layout... even if you use a tileable texture map, you may still see "seams" in between UV islands... no matter you set Tiling values with integers or decimals ~~
    However, there's no "priority" in tiling but just a simple multiplication, i.e. an Instance Tiling values mutiplies by a surface Tiling value (Horizontal / Vertical).  Only difference is that the settings in surface Tilling affect all layers / slots, while the Instance Tilling set in a certain slot just affects that slot.
  • Ah, ok, thank you very much! So if I use these values on a simple plane primitive, with its default UV, there shouldn't be any seam on the plane's surface, is it that?
    That's correct ~
  • Great, thank you very much! laugh Last question (I hope): after creating several "instance tiling shader", I thought that they would be better in a specific folder, and I deplaced them. Now, they still work correctly, but I noticed that there is not the "shader" inscription anymore, on their image in Content Library:
    Before moving in another folder :       After :
    Is it a problem? Is there a way to fix it without having to "create again" the shader?
    Right ~ when you save a Preset for the 1st time, DS will tag a metadata, i.e. Content Type ( Shader in this case...) to the DUF file and write its path + file name to cms database. Then if you move the DUF file to another folder, the path + file will be broken in cms database... that's why you saw the Shader icon on the thumbnail is gone.
    So, to bring it back, in Content Library, right-click on the current folder that this preset file locates > Edit Metadata, select the file in the list, then set Preset/Shader to Type field. (ss1)
    1146 x 841 - 38K
    Ah, I just saw your answer! Thank you very much! laugh
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,769
    not sure if mentioned but it creates temp folder images for rendering you can save and reuse
    Ah? What do you mean? It doesn't create an actual shader preset?
    the Layered Image Editor itself
    creates image files in your DAZ temp folder it deletes after you close the scene
    Do you mean it couldn't be applied in a new scene? After combining several images and a color layer in the LIE, I saved it as a shader preset. When I open a new scene and load a new object, the shader preset that I created seems to work correctly... Have I misunderstood something?
    I meant you can grab the images and reuse them without the shader preset if you want a tiled image
    I am probably causing unneeded confusion by pointing this out
    sorry, just ignore eveything I said, it's more useful for other purposes like exporting or creating maps you can edit
    Ah, ok, I understand better, thank you very much! laugh Well, evven if i donn't need it for now, it's still quite interesting! How can I find this temp folder to access these images?
    edited March 2025
     if it's in the default spot it might be in the DAZ3D folder in your documents
    or in application data roaming DAZ3D
    I set my own path in preferences so don't actually know
    you can briwse to where your temp image is in the surface tab too
    it will vanish when you close DAZ studio though
